mazikowski »
https://forums.nicoclub.com/mazikowski-u67058.html
Sat Feb 26, 2011 9:14 am
I have a 1991 D21 with the KA24E. Before getting it, it seems to have been severely neglected all its life. Recently we replaced the oil pump and ever since we have had a strange (and most likely unrelated) problem. It will start but after running for 10-15 minutes if you turn it off it will not start back unless it sits for about an hour. If you start it, let it run for a little bit (30sec - 1 min or so) and turn it off, it starts back up without a problem. We have replaced pretty much the entire ignition system (including plugs, wires, cap, rotor, coil, ignitor [the little god-awful-expensive thing mounted to the coil bracket]) and are still having this problem.
Any ideas?
