VStar650CL wrote: ↑Fri Apr 26, 2024 8:52 am
Not a bad idea using bearing races for cups. I like it.
Yeah and the bonus for me is I'm pretty sure the backside cup was in good shape, the rod had just started disintegrating so there wasn't as much movement as the fella that I got the post specs for the repair. Vehicles here in New Mexico just don't have the rust issues like anywhere else I've lived. So parts stay reasonably well shape, even 34 years old, all things considered.
I read further and his repair is based on someone who had this similar problem with their Ford. That tells me this is an engineering flaw and that the bushing on the compression rod that is in front of the frame is the culprit area that gives out causing extra damage later on.
So it would stand to reason that I only need to weld in a proper fitting (the cup spec) to the front area where the up and down movement of the lower control arm causes that bushing on the front to want to travel around that saucer cup on the frame. (which it apparently does even on other models that have that same saucer cup style).
I'll follow the spec designs but without knocking off the original bushing cup on the backside of the frame and will just use the brass insert/washer and nut on it to secure the front for welding into spot. (if that backside bushing cup is in good shape only-I'll do a closer inspection and evaluate afterwards).
