ManzanoNissan »
https://forums.nicoclub.com/manzanonissan-u301164.html
Thu Aug 29, 2024 4:52 pm
1991 D21 4x4 just finished replacing the suspension and steering all the way around, just got back from town from a wheel alignment and she died on me a mile from home. She died just like she did when the fuel pump when out on her last year, except as I pulled over you could smell burning plastic and you could see smoke coming from the passenger side of the hood, right where the relay box is.
Checked the fuel relay and the main relay and both were fine. Switched out with another nissan's relays, no difference, she turns over but no spark. Tried starter fluid, no luck. Removed a spark plug wire and grounded it and we could see no spark.
All the spark plug wires, distributor, coil all new.
I would have a tendency to think the coil is bad, but I can't ignore the fact smoke/burning was happening under the hood.
The relay box does not show any fire damage, could not find scorch marks anywhere.
Anyone ever have something like this happen?
I'm suspecting the box/housing where the relays go in.
