silviasalsa wrote:Hello i amtrying to decide in buying between a ls 400 or a q45.
1.) in a q45 what are the main problems
2.) maintainence?
3.) is it expensive to maintaine?
4.) what is the actual mpg?
1.) Poor owner maintenance.
2.) About 15¢ per mile once rehabilitated to as new OEM specifications.
3.) Depends on how much you can do yourself. Usually much less than other large imported luxury V8 sedans.
4.) Mine is 17 to 18 mixed. But if you are worried about mileage, an imported luxury V8 sedan is not your cup of tea, believe me.
The 1994 and later do not have the timing chain guide problems. Maintenance history is everything before the actual inspection by yourself then an Infiniti Senior Technician.
Read the Sticky Buying Guide above and read all posts by Q45tech and you could save thousands.
Modified by maxnix at 7:54 AM 10/19/2007
