Kevs300zx »
https://forums.nicoclub.com/kevs300zx-u283039.html
Tue Jul 10, 2018 1:45 pm
Hello any help please
I have a 1991 300zx TT 5 speed, having a issue getting it started, it will run with starter fluid, but once its gone car cuts off, changed CAS , cleaned the connectors for PTU and and on the CAS, removed the CAS and turned the shaft for the Injector click and heard none, new fuel pump but not priming either, not sure what it is at all, cant tell if the ECU is the issue, if anyone have a helpful word if will be appreciated.
Thank you in advance
