1991 300zx cuts out at 2500 rpm
dctobin
Car: 1991 300zx 2+2 N/A
I have a 1991 300zx N/A. 69K miles. When I start it up, it runs fine. then, after running for 10 minutes or so, it starts cutting out completely at 2500 rpm. starts bucking, etc. Sometimes it will get back above 2500 rpm if I rev it out of gear. It also seemed worse when low on fuel, so I installed a new fuel filter, but the bucking/cutting out, while better, still exists.
Any ideas?
Thanks!
JosefTTZ
Car: 1991 Nissan 300zx TT
That sounds like a bad MAF (Mass Air Flow Sensor). Check your ECU codes and see if the MAF code comes up. I have also seen no codes even though a MAF was bad. You can also borrow a MAF from someone and swap it, see if that fixes it.
evildky
Car: 71 Datsun 240ZT
87 Nissan 300ZX N/A-T
06 Nissan 350Z GT
Toyota Tundra TRD RW
the "bucking" thing kinda sounds liek a failing fuel pump, that and you said it gets worse when low on fuel, the fuel helps to keep the pump body cool, when low on fuel there isn't enough fuel to keep the pump cool, kinda a pita but you might want to get a length of fuel hose an a fuel pressure gauge, and rount it under a wiper arm where you can see it when driving, and see if it drops when the problem occours, I've seen this on S130's but not on Z32's
300freekzx
Car: 1990 300zx N/A, 1992 Honda Accord LX , 1991 Honda Accord LX, 2006 M35 Sport
evildky wrote:the "bucking" thing kinda sounds liek a failing fuel pump, that and you said it gets worse when low on fuel, the fuel helps to keep the pump body cool, when low on fuel there isn't enough fuel to keep the pump cool, kinda a pita but you might want to get a length of fuel hose an a fuel pressure gauge, and rount it under a wiper arm where you can see it when driving, and see if it drops when the problem occours, I've seen this on S130's but not on Z32's
I will be money it is the coolant temp sensor. I would find some one with a conzult to diagnoss the problem first.
evildky
06 Nissan 350Z GT
CHTS ususally just floods out and won't restart
dctobin
Hey guys --
First, let me say that this forum is fantastic. I had no idea what "check the codes" meant, and went to the how-to section and got instructions to check it.
So, my codes are 12 and 53. I guess I should check the MAF, as originally suggested? Perhaps check the contacts and/or replace.
How about the 53 code? what do I do with a problem with the exhaust gas sensor.
Thanks again -- I really appreciate it.
evildky
06 Nissan 350Z GT
code 53 is right side O2 sensor
JosefTTZ
You probably just need to get a new o2 sensor for the code 53 to go away. You may have also noticed a decrease in gas mileage since the o2 sensor may be malfunctioning.
As for the MAF, that is why you cant go above 2.5K RPMS. The o2 sensor wont cause this.
dctobin
Today I pulled the harness on the MAF, then pulled out the MAF. Everything looked fine. I voltage tested connector B on the MAF, and it came back at .03 volts. I understand this is supposed to be at .8-1.5 at idle. I guess I should go ahead an order a new (reman) MAF?
Thanks again for everyone's help.
dctobin
Guys --
thank you! after reading your advice, checking codes and voltage, i ordered a replacement MAF. I installed it today, and the car now runs like a top! It sounds great, too. THe MAF code "12" has disappeared as well, leaving only the code 53 for the right side sensor.
So i am going to order a replacement sensor. Now, for a silly question -- i assume the right side sensor is the passenger side? And i understand that one is easier to replace.
Anyway, thank you for all your help. Knowing next to nothing about cars, it is great that I was able to fix this issue with your help.
jdmshiz
its how i feel when i have a problem and don't know how to fix it.
dewdog
Car: 1993 z32
my cousin had the same problem with his vr6. he didnt want to spend the money to fix it so he sold it. the kid that bought it put a new battery in and it worked fine.
JosefTTZ
Awesome, usually when Z's dont want to go over 2500RPMs than it is more than likely the MAF.
Glad you fixed it.
300ZXing
Car: 1991 Nissan 300ZX
2+2 Z32 Automatic
Does anyone know what would be the best code reader? I have the same problem with my zx.
on my 3rd maf, 2nd tps, and still can not fix.
nissanfreak12
Car: 92 300zx 2+2 TT
300ZXing wrote:Does anyone know what would be the best code reader? I have the same problem with my zx.
The best code reader is already in the ECU or Datascan, but the ECU does well enough. See below.
https://www.google.com/url?sa=t&rct=j&q ... 6858,d.aWM
z32loverboy
Car: 1990 300zx CRP N/A 5 Speed (wreaked, now a shell) SOLD
1993 Slicktop CRP N/A 5 Speed w/ '90 built N/A motor and interior
1958 Ford f-100 straight-body (Grandaddies truck, resto-project)
Nice write up! great info right there!
