If someone slapped a turbo and nos on it, did they build the block or leave it stock? If it was left stock, I'd consider doing a compression test on it.
As for the bogging, is the car acting like it's hitting a fuel cut at 2500, or is it just falling flat on its face but still revving over 2500? Usually if it hits the cut off and refuses to rev over 2500 under load, the ECU is in limp mode. If the car is in limp mode and you've checked and verified the MAF, TPS, and coolant sensor are indeed in operating order, then it could be a malfunctioning ECU. Since you mention the harness has been messed with, and I'm assuming a shoddy job was done since you say it's ghetto rigged, consider getting a multimeter and confirming all the values of the TPS, MAF, and coolant sensor are performing per the FSM. You can get a copy of the FSM at our
Service Manual Library.
