1991 240sx: what parts of steering and suspension fail with age?
vancouverbc
Car: 1991 240sx
I have 185,000 miles on my car. I was wondering what parts of steering and suspension need replacement or maintenance at this point. thanks.
Dammitboy
Car: 92' Nissan 240
Outer tie-rods turn to dookie. Mine actually broke while driving.
adrianfromthecastle
Car: 1992 Nissan 240sx
Dammitboy wrote:Outer tie-rods turn to dookie. Mine actually broke while driving.
and ouch...
might also want to check out the tie rod boots and tc rod bushings (most likely blown as well)
vancouverbc
Car: 1991 240sx
thanks. this guy replaced entire tension control rod. not sure if it is better to just replace bushing
http://www.nicoclub.com/articles.php?id=255688
adrianfromthecastle
vancouverbc wrote:thanks. this guy replaced entire tension control rod. not sure if it is better to just replace bushing
Oh yeah, definitely easier.
Highly recommended. Just make sure you choose a reputable brand.
cmoody2006
Car: 1993 Nissan 240sx vert
My shocks went out around that many miles.... Might check those as well
nismotuner1
Car: s13 Hatch
05'Titan
vancouverbc wrote:I have 185,000 miles on my car. I was wondering what parts of steering and suspension need replacement or maintenance at this point. thanks.
I would replace everything if I were you. I have a 93' with 174,000 and I dont think it has a good suspension part left on it. I love how it klunks real loud when I hit the brakes(worn strut tops). Im doing a sr swap now and I plan on replacing everything on the suspension. I'm also going to change the steering rack b/c mine is starting to leak
MaxFNPower
Car: 93 240sx SE Coupe KA24DE (My Dorthy) 97 240sx Coupe KA24DE(Un-Named) 87 Nissan Pick-up (Tin Man)
nismotuner1 wrote: I would replace everything if I were you. I have a 93' with 174,000 and I dont think it has a good suspension part left on it. I love how it klunks real loud when I hit the brakes(worn strut tops). Im doing a sr swap now and I plan on replacing everything on the suspension. I'm also going to change the steering rack b/c mine is starting to leak
I have a 93 and I've been checking. The only thing actually shot on mine is the struts, I was surprised at this, but I'm still looking at upgrading. Look into it some times it's not all that more expensive to upgrade instead of just replace.
