1991 240sx: What are the symptoms of an aging MAF?
vancouverbc
Car: 1991 240sx
How long do MAFs usually last? Should you buy new/refurbished or used MAFs?
adrianfromthecastle
Car: 1992 Nissan 240sx
what's wrong with your mafs?
symptoms include: black smoke out the exhaust and/ or bogging at idle.
if so, you might be able to save it with a mafs cleaner.
zerothread?id=282308
vancouverbc
Car: 1991 240sx
Thanks:)My idle is fine but it does dip down(nearly stalling) when I come to stops. My idle is rich , at least the voltage from O2 sensor suggests it is rich.
When I cleaned the maf sensor, the element had a crusty white substance on it. I assumed that was normal.
i didnt realize you could take the sensor out like that. I opened up the back and sprayed in the hole.
driftingmy240sx
Car: 1996 Nissan 240sx rb25det
you may have a iac out of adjustment
Dracolove
Car: 95 Nissan Maxima
I know on my maxima i would come to a stop at stop signs, street lights, and even just slowing down for a turn and my car would just shut off. I had the MAF replaced and it runs great now.
vancouverbc
Car: 1991 240sx
I wish i had a known good maf. it will cost about $300 to buy new one.
240FeVeR
Car: 1992 240sx Coupe!
Your car can run without the maf..just not through the whole rpm range. Unplug the maf and see how the car runs at idle...if the problem goes away its your maf. As for cleaning it, take a q-tip and cleaner be VERY gentle and wipe the element. When I say gentle I mean gentle.
vancouverbc
Car: 1991 240sx
My car runs good at idle. The problem is when I come to a stop. The idle is terrible if I disconnect the MAF. I guess I could try stopping with MAF disconnected.
Is the maf sensor supposed to be coated with a white substance? When I rub Qtip on white stuff it is very prickly. It is a very uneven surface. The cotton catches on the uneven parts of white substance on sensor.
/[QUOTE=240FeVeR]Your car can run without the maf..just not through the whole rpm range. Unplug the maf and see how the car runs at idle...if the problem goes away its your maf. As for cleaning it, take a q-tip and cleaner be VERY gentle and wipe the element. When I say gentle I mean gentle. [/QUOTE
nissangirl74
Resurrected from the archives! I was wondering if anyone in this thread could help a new guy out.
help-maf-sensor-part-number-t577871.html
Thanks!!
