p00t »
https://forums.nicoclub.com/p00t-u5026.html
Thu Feb 12, 2004 11:35 am
[quote=" Shadar Yeah it looks like it was the throwout bearing. I'd heard you could fix it by putting grease in through the dustboot that protects the clutch fork, so i did that.
and it did fix the problem a little, although it's not entirely gone. i did however succeed in getting grease on the flywheel or clutch plate or something as my clutch now slips;) so i have to drop the transmission anyway.hehe
ah well, practice makes perfect:)
anyway, i have a few other questions on problems my car is having that may be transmission related.
the metal to metal noise i get at about 4k rpms, it seems to only appear right around there, no where else.maybe it's a chain thing? happens in neutral/any gear.
One of your heat shields is rattling, theres ones on the exhaust from the cat all the way to the engine, i had to remove all of mine to get rid of every noise (mine used to occur around 3.5-4k rpms). It sounds almost like a metal reciprocating saw on metal sound right? You can either remove the heat shields or live with it. Only downside is when the exhaust manifold heatshield is removed your engine bay temps will go up alittle, but it wont be bad, your choice. You cant remove them and try to tighten them back down, the bolts are all very rusty, most of them will break when you mess with em.
and after i drive my car fast for a while, on the highway or whatever, when i stop i get a strong burnt odor from the car, it's not noticably inside but definitely noticable outside.
That would be your brake pads, thats normal when you do a hefty stop from high speeds.
hrm....think that about covers the things i'm curious about, and how important is it to replace the pilot bushing? i didn't get one with my original clutch kit, but since i'm dropping the transmission again, and i'm having problems. i think it might be worthwhile to pick one up, and maybe an OEM TO bearing while i'm at it.. ?
I replaced mine at 96k, but it isnt completely necessary, just put the clutch alignment tool into it and see how much play there is, if it can move around a bit side to side you should change it. Use your own judgement here. Make sure you get a nissan replacement though, i got one from a local auto shop and i couldnt even get the transmission in so i had to pull it back out and sand it :rolleyes
anyway..
thanks a lot for your help,
Ben[/quote]
