1991 240sx
racerd240
can anybody tell me the measurements of the 240sx frame
mine was recently involved in an accident and i want to see just how far it's off
Thanks
Axel Grungy
Car: 2001 G20 5spd
thats pretty vague, might want to give some specifics, which part etc...
racerd240
the actual frame itself. if you measure diagonally what is the dimensions
thanks
gumby
Car: '89 240sx sohc
I'm not sure what bolts to measure from on the front strut towers buts its 45 & 1/2" from the center
racerd240
how about the width and the length its self
my whole problem is after i put a new tension rod bracket and tension rod on the left front tire sits an inch back farther than it should and the tire is pretty much driving on the outside two inches. also could you replace the arm off the left side of the rack and pinion or do i have to get a new one altogether i think its bent also
Thanks
Tsukai240
uh.....isn't the s13 a UNIbody. therefore it dosn't have a "frame". i would measure the deformation using refrence points on an unwrecked body and compair. correct me if i'm wrong.
racerd240
do you have a good s13 they are pretty rare where im at
lenso
Car: 1993 240sx hatch
check out the FSM, they have dimensions with reference points.
racerd240
whats FSM
420_240sx
Car: Blazing it, driving, computers.
Factory Service Manual
