s13drft89 »
https://forums.nicoclub.com/s13drft89-u31033.html
Sun Jan 29, 2006 1:15 am
Yes it can be done, now if your shaft(for holding the throw out bearing) was moved then I would think (dont qoute me) it would needed to be removed. Now if you have the shaft and everything that came out from the slave its not hard to put it back in. Just release the pressure thats still in there, or else your not going to be able to stick back in the rod. But in that case i say just go down to your local auto parts store and buy another slave, should only cost about 10 bucks, very easy to be put in. Also make sure you bleed the system before starting up the car and enganging it into a gear. Its easier to bleed then the brakes, also if you have that boot that goes over the long shaft(holding the throw out bearing) put that back on for sure you dont want any rocks or dust getting into your clutch etc..-Ricky
