1991 240sx: O2 sensor unplugged but not getting a code
vancouverbc
Car: 1991 240sx
I'm getting other codes but not the code for O2 sensor. The mode 2 self-diagnostic test indicates the fuel mix is good.
vancouverbc
Car: 1991 240sx
Just remembered that the O2 sensor doesnt do anything below 2000 rpm.Ill have to test above 2000 rpm.
vancouverbc
Car: 1991 240sx
I tried over 2000 rpm, and cant trigger the O2 sensor code.
The voltage reading is a little under 1 volt for the O2 sensor.
180fan
Car: 89 fastback
consistently? That voltage should bounce back and fourth between 0 and 1 volt.
vancouverbc
Car: 1991 240sx
The O2 sensor voltage starts off at around .2 when engine is cold and gradually rises to around 1 volt. I'll have to try this with the O2 sensor connected to ecu. The 1 volt reading at idle does suggest a rich mixture. Not sure how reliable this is.
vancouverbc
Car: 1991 240sx
An old or dirty o2 sensor will read lean so that is not my problem. I cleaned o2 sensor anyway. Before cleaining, I did test the O2 sensor with it connected to ecu. There was no difference during idle(volts were close to 1, still) but above a 1500 rpm, the reading went crazy alternating from .2 volts .4 to .5 to .8 volts. This makes sense since O2 sensor does not attempt to control anything until 1500-2000 rpm. I wish there was a definitive way to know if you are running rich.
MTX450
Car: Black S13 KA-T // Maroon S14 KA
I don't know if this thread is still active or not, but I just wanted to shed some light on a similar problem I am having. I just noticed that the car today was running like crap (usually is) and so I figured I would pull the o2 to see if there was any difference in performance. I know for a fact that when you pull the o2 sensor, you are suppost to get a CEL. Well, in my case, I get nothing. Current symptoms are hesitation between like 2500-3000k and ****ty idle (Need to clean out AIV). Oh, and I get like 20mpg. My question is, what is causing the car not to throw a CEL? Is it possibly a faulty ECU? I have also rebooted the ECU numerous times (starting and stopping motor)
vancouverbc
Car: 1991 240sx
Mine turned out to be a bad ecu. I did get a rich code and other codes worked. As you say, a disconnected o2 sensor should produce code.My symptoms were subtle and only detected by emissions test.
The best place to get ecu is in the forums when people part out their car.
MTX450
Thanks!
I'm gonna go get a new o2 sensor, and put it in and see if it does anything...just for the hell of it
If it doesn't help, I will look into a new ECU
