Soy »
https://forums.nicoclub.com/soy-u13809.html
Mon Feb 20, 2006 3:29 pm
Hey guys and gals - got an interesting problem...My brights don't work on my s13. I've replaced the bulbs, and no dice.
When i click over to brights, the light in the dash comes on, but the headlights just die out completely. If I try to flash my brights, again, the light comes on, but the headlights don't flip up, nor do the bulbs activate.
I've checked the switch on the tree - it seems fine, though I don't have anything to replace it with to be completely thorough. However, from everything I've read, it seems as though it would be the relay under the hood? All the fuses (both in car, and under hood for headlights) are good, so I can only assume it's a relay problem.
I don't hear any relay fire when i try the brights... shoud I?
Also, which relay would it be that needs replacing, and how would I go about checking to see if it actually works, outside of hearing it click over?
...on a similar note, my cruise control isn't working either. The switch on the bezel turns on and off, and when I use the steering wheel controls the light in the dash turns on and off, but the cruise itself never engages.Are these two related? Do they run off the same relay?
(As you can tell, I'm not exactly an electrical guru... I'm more of a motor guy)
Thanks for your help in advance.
James
