coltsd44 »
https://forums.nicoclub.com/coltsd44-u123126.html
Sun Mar 01, 2009 8:50 pm
for a rough idle. try a grounding kit. look it up, make your own its cheaper, and it helped me a lot!
also, do a tune up. new spark plugs, wires, fuel filter, air filter, cap, rotor, oilthat could never hurt (however, filters and oil will not help out with rough idle too noticeably, but do it anyways)
as for the shaking, make sure ur motor mounts are intact(not broken) and if intact, tighten them down.
however, the motor is going to shake no matter what. so it might be normal, just not normal compared to what u are used to.
hope it helps
