Hijacker »
https://forums.nicoclub.com/hijacker-u9394.html
Fri Dec 09, 2011 7:14 am
Price for price, I would go with stance over megan for coilovers. I want to try out the fortune auto ones since the company that brands them is nearby to me. I've heard good stories from them, but nothing about long term durability yet. I was going to shell the few extra hundred for SPL's KTS coilovers, but they discontinued carrying them a few years ago.
And it's very easy to feel better than stock since stock bushings tend to fail rather quickly and have a lot of room for slop in them. TC bushings are the most notorious. I popped NISMO hard rubber bushings in my TC rods, and that felt better. But feeling better is still not indicative of performance, which is where my mind is concerned. Something can feel better, but if it throws your suspension out of whack, and makes the car turn like poop, I'd rather have the soft pillow bushings.
For swaybars, I would go with whiteline. It's not hard to screw up a swaybar since it's just a bent piece of steel so Megan is a good alternative there, but whiteline allows adjustability in their setups, which is invaluable when you're tuning a suspension to perform. For endlink bushings, I would consider whiteline or energy suspension. Rubber compounds are one of the first places I look at for failures when I'm comparing budget parts to higher priced parts. I've seen a lot of knock offs (read knock offs, not necessarily making a judgement verdict against Isis or Megan) that just seriously fail on being able to replicate the complex chemical makeup of a company's rubber compound. Any person that works for a rubber plant of some kind will attest that the start up process for the mixing vats is different on each start up just because of chemical reactions during the mixing process. Each vat has to be tightly controlled to make the outgoing product within spec (a neighbour of mine was a plant manager for Yokohama, he was a good source of insider info for general processes like this).. This is where I make the quality control argument. Budget companies aren't as concerned because they use lower grade rubbers and polyurethanes. Again, for someone looking to just add a bit of pep to their cars, it won't make a hill of beans difference, but if you want to become somewhat competitive, it can be a detriment.
