dubbs693 wrote:I have to take out the cluster to get at these things?
You should search... for gauge lights, interior lights, dash lights, etc - this problem has been addressed literally hundreds of times.
The dimmer switch is the one on the gauge bezel that lets you turn the light intensity of the dash/climate control up & down. You can pop that one out by yourself.
Most likely, it has to do w/ the way your head unit is wired, most installers tap the wrong wire and it messes up climate control and/or dash lights.
Completely unplug your head unit & see if you get any lights back.
Then check to make sure you didn't sever any power wires to tap into the HU (i.e. 12v & ACC wires).
Then search some more.
