DemonZ »
https://forums.nicoclub.com/demonz-u88594.html
Tue Feb 12, 2008 6:34 am
When does it overheat normally? Does it only overheat when you come to a stop or ar in traffic? Or does it overheat even when you are at a 70mph roll?
There are three common things that cause overheating, first is the thermostat, second the pump and third, the fans.
Having a plugged up radiator is still kinda common, but not nearly as common as the first three things I mentioned. Lastly is Air pockets in the motor itself, very rare but it still happens.
If you're overheating mostly in traffic or at a stop, it's probably your fans.
If it was your thermostat, then turning on your heater would help cool the motor down atleast somewhat. Infact... turning that heater on should help atleast a little with any problem you have. So that's kinda strange to me that it has no effect.
Since you replaced the pump and the car does operate at a normal temp now and then, I'll eliminate that as a possible problem.
As I was typing this out I had another idea, since it's not something that happens on most cars and since you said turning on the heater doesnt help I dont think this is it... but since you did mention that the car ran at normal temp today, and it was a mild day, I'll throw this question out there..... Again, this is a rare and since you live up north, probably not likely.... but, do you have A/C? And if you do, has it been retrofitted for R134a? Occasionally on older cars you can get a restriction in the A/C system that can cause a major pressure build up and when you have the A/C on for a while the whole system can heat up so much that the condenser(that's the thing that looks like a radiator that sits in front of your real radiator) gets super heated and since it's pretty much attached to your radiator, it will cause the radiator to heat up quite a bit over normal operating temp causing you car to overheat.... I've only seen this happen on 2 cars, but it is a possibility.
