1991 240sx: how do i check for a bad clutch
xckid
Car: 2004 Chevy Blazer ZR2
My car is approaching 180000 mi. I dont think it has ever been replaced only slave cyclinder . Another reason i want to know is because it sometimes just pops out of gear when i put the clutch in and i go to move it feels like it just popped out. Also how far are you supposed to be able to push the clutch pedal in before disengages the clutch and engages< (sp) my pedal is like almost all the way out when it engages and dis.
180fan
Car: 89 fastback
yeah I'd say your clutch disc is done
xckid
Damn serious. *sighs* it still holds but . I would figure it eventually would give out like not even let me put it in gear
xckid
What happends if i keep driving it. this is my Daily Driver.
180fan
Car: 89 fastback
prob slipping all the way since it's not really the disc that's totally done for but the disc/pressure plate. so yeah eventually you won't be able to shift and will need a tow home. around my neck of the woods, that can cost as much as a new clutch disc and pressure plate.
240Extremist
Car: 1993 Nissan 240sx se Fastback
I have the same problem on my '93 hatch and I'm getting ready to replace my clutch also. If you are wanting a stock clutch, you can go up to O'Reilly auto parts if there is one around you and get one for $140. They get the whole kit for you and if you are wanting a new fly-wheel they have those also for $85. They'll also turn the fly wheel for you for an extra $25. It's the cheapest I've found for a stock clutch kit for the 240's. Hope this helps.
xckid
Thank you all of you this is alot of usefull info. time to start saving.
240Extremist
Have you gotten your clutch replaced yet or are you still saving. Let me know how it went if you did get to replace it.
