1991 240sx Fuel injectors not firing
gagegregory
Car: lexus ls400
Hey guys, work at a performance shop here in knoxville , I did a ka24e to ka24de swap . The car ran with the ka24e now once I havce it all wire up and what not the fuelk injectors arent firing ... It will start on starting fluid but the injectors just arent pulating . I checked all the grounds and they look good . its not throwing anything but the 55 code wictch means everything is ok . Just wondering if there is anything I am looking over . Any help will be greatly appritiated .ThanksGage Gregory
clss240
Car: 1990 240sx hatch
trying to diagnose the same problem here after swapping in my s14 for the s13 ka. i'll let you know what i find. you do the likewise
gagegregory
Car: lexus ls400
im probably lookin over sometin stupid but its bad pissin me off .
skaterfromvt
Car: 1989 240sx sr20 blacktop Built not bought 87 v8 rx7 fc3(50) 95 s14, 00 dodge ram 1500
Did u ever figure it out...i Cant get fuel to spray from my rail either?...sr20det
danielsan
Car: 1991 240sx coupe SE
crank angle sensor fires the injectors. its in the fsm on how to check them. pull the distributer off but leave the harness connected. turn the shaft on the distributer slowly and listen the injectors they should click one at a time i think.
check that first.
skaterfromvt
zerothread?id=334075
heres my problem?
kind of similar
skaterfromvt
With one ecu if i pull the cam angel ...with the junk ecu it fires 3 of the 4
with the e5 ecu i pulled it and and spun it by hand and it didnt fire any of them what could this be?
180sxn
Car: 95 S14 240SX SE
You have to swap ecu...or adjust distributor back 23 degrees
skaterfromvt
I pulled the cover on the e5 ecu and it was fried...I wish i Pulled it and opened it before i started / started swapping harnesses 4 times!!!
Now with the junk ecu...im not getting any spark and have set the distrib 10 different times...
also I pulled it out and set the wires back on and spun the dis...and could not hear any of the injectors clicking...is the junk ecu finally fried too?
