wheelsspin »
https://forums.nicoclub.com/wheelsspin-u40545.html
Fri May 18, 2007 4:09 pm
The EGR system is designed to control NOx, so that is the best place to start. Check vaccum lines to and from, and pesky carbon buildup at the EGR and it's piping. Another cause of high NOx can be lean mixture. Check fo vaccum leaks - a bottle of propane or the like over the hoses makes the idle change if you have a leak. One more thing - overadvanced timing could do it to, so set it back to factory spec if it is out. All of these would also cause the higher than normal hydrocarbons.
