fullmetal wrote:ok so I tryed the gravity bleed and it did nothing no more air then before. At this point I have blead it from the valves at both the cylinder and the little box thing and by the way if any one knows what the box is that the line goe into before going to the cylinder I would appriciate the proper name so as to stop calling it "that weird box thing." the only real progress is that I pulled the valve from the box all together and un-clogged it because it wasn't flowing at all. I am still very confused could some one please give me something, any thing??
that little box is called the clutch damper box. its useless and makes bleeding your clutch 100% harder than it needs to be. if you take that box off and bend your hardline to where you can screw the rubber line into it, it would make bleeding your clutch easier/less time consuming. its not hard, but if you attempt this be very careful not to kink the hardline. i did mine, and it was hard to bend at first, but after a few mins of putting pressure on it it started to slowly bend. then youll need to refill your clutch master cyl and re bleed the system. shouldnt take but 10 mins to bleed if even that.question: why did you bleed the clutch in the first place? did you replace your clutch master/slave cyl? replace a busted line? or what?
