1991 240SX: Clutch pedal non-responsive
91_240SX_SE
Car: 1991 240SX KA24DE
I recently replaced the clutch line for a stainless steel one since the stock one was leaking and I also replaced the clutch master cylinder as well. I bled the system like I should, but the clutch pedal still seems to be non-responsive. Is there a chance that any fuses/relays may have shorted out? The car still starts when pushing the pedal down, but that is where it will stay. Doesn't pop up to where it should. Any help or suggestions would be appreciated.
aceof07
Car: 91 240sx
have you checked your fluid levels? check them again and report back in.
91_240SX_SE
Fluid levels are are all good. The master cylinder is filled to the max level indicator.
aceof07
Car: 91 240sx
so your master is new maybe you killed your slave cylinder, happened to me. and also delete you clutch fluid box while your at it. makes bleeding soooooo much easier.
91_240SX_SE
i'll give it a shot and see. thanks for the help
jrich068
Car: 1987 Nissan 300zx
Yeah my slave cylinder just went and i had to replace it. I was having the same problem with the pedal sticking to the floor. But once we correctly bled the system is was back to normal.
