180fan »
https://forums.nicoclub.com/180fan-u3602.html
Fri Oct 20, 2006 5:18 pm
If you look at the plastic section that comes up from the body, you'll see a little topper that's got some grooves in the top. You need to undo that topper and the antenna assembly will fall down after you pull the bolts that are holding it onto the chassis that are behind the interior panels in the trunk. I had to take a cutting wheel to mine to get it out and something tells me if you've got an s13, you'll be in the same boat.
