Wrote that backwards. The fronts can be pressed in, but the backs are useless. I thought the 300zx axels were a different size then 240's. thus the axels wont go in.OutToWinPAHC wrote:Well your not searching.
You can use the rear hubs,, just bolt them on. The front are useless. though.
With the right coils you can use the aluminum Z32 rear uprights, backing plates, rotors, calipers, booster, BMC, e brakes cables. A good pick up for 800
