nissans13240sx »
https://forums.nicoclub.com/nissans13240sx-u37868.html
Sun May 18, 2008 4:35 pm
check power to starter. if power is good check signal to starter(smaller wire)(also must be done while turning key to start position). If signal is good your starter is bad. If signal is bad, it could be a bunch of things, clutch switch or park nuetral switch, break in the wires, etc etc...
