It really is a job for a mechanic. There is a black with red stripe wire that goes from ignition to ignition coil and to two 10 amp fuses(fuel pump and engine cont) in the relay box(see link) by battery. I would have an extra fuse in there because you dont want to blow the fuse to your ignition coil or fuel pump relay fuse.annunziato39 wrote:where would one of these ignition controlled wires be and how do I connect to it. As you can tell, I'm not very good with wires.
