I would get a hydrometer to test battery. They are only 5 bucks. Also, a digital multimeter for about 20 bucks. a battery booster/jumper would also be good investment.
Alternator test using volt meter:
1.turn headlights on for 15-20 seconds to remove surface charge2.measure voltage across battery when engine off3.turn off all electrical loads ie wiper ,etc4.start engine and increase speed to 1500 rpm5.measure voltage across battery with engine steady at 1500 rpm
the voltage reading should be at least .5 volt higher with engine running. if voltage goes up more than 2.5 volts, alternator overcharging.
You can also test with engine running with lights on at 2000 rpm. the voltage should increase at least .5 volts
http://www.uuhome.de/william.darden/carfaq.htm
