1991-1993 240sx: Idle drops 100 rpm when interior fan is turned on
vancouverbc
Car: 1991 240sx
It drops and stays lower until fan is turned off. If I turn on headlights it drops another 50 rpm. You would think the computer would just bump up the idle. The alternator is relatively new but has a bad bearing. I read 14 volts at battery when car running.
Dittoz7
Car: 1997 2f0WtY SE!
Ok
ricebike
2002 Quest
2005 Altima
vancouverbc wrote: The alternator is relatively new but has a bad bearing. I read 14 volts at battery when car running.
umm yea your key words= bad bearing; common sense will dictate that it's causing the drag
get it replaced; most aftermarked rebuilds should have a limited lifetime warranty or if you got the cheaper version, a 1-year warranty or junkyard special up to 90 days
vancouverbc
Car: 1991 240sx
I replaced the alternator but the idle still drops and remains dropped when heater fan is turned on. I think it is normal for the 240sx.
NISSAN240SX12
Car: 1993 NISSAN 240SX SE COUPE
1991 Toyota Supra
add another alternator to it! J/K.
