1990 z32 2+2 stoplamps not working!!
noboost300
Car: 1990 z32 2+2
ok heres the deal, my third brake light works and my tail lights come on, but when i apply the brake the left and right lights do not light up. the bulbs are good and so is the fuse and since the 3rd light works im assuming the switch is good so what else could it be??
Q451990
Welcome to NICO!
This is a common issue on the early Q45's, and from reading the service manual for the Z32, it appears they have a similar setup. The stop and tail lights are monitored through a sensor that illuminates a light on the dash if a bulb burns out. When this sensor fails, you end up with what you describe. Check out your service manual at http://www.nicoclub.com/FSM/
The location of the sensor is on page EL-113. If you're handy with a soldering iron, you may be able to repair the sensor if something is melted internally.
This is typically caused by excessive current draw in the circuit. Replacing all of the bulbs with OEM Nissan bulbs, or Sylvania LL bulbs will help prevent it...
Good luck!
Heath
