1990 Sunroof Gasket replacement
BCC93QT
Car: 1990 Infiniti Q45
1995 Infiniti Q45
Sunroof rubber Gasket needs to be replaced. Been keeping it together with some touchups. About an inch gap in the rear that starts leaking when rains. Not in cabin but eventually. Doesnt leave the garage much. Long shot here. Who's got experience with this between the last 3 people on earth that have one of these. Discontinued part. Im guessing it shares another type of gasket of another car but what
VStar650CL
Technical Expert
2004 Nissan Altima 2.5 S
Amayama has them in Osaka but they're $150 plus shipping:
https://www.amayama.com/en/part/nissan/9124660u00
Lid gaskets are pretty much all the same, there's a ribbed lip on the inner perimeter of the gasket which you compress into a slot in the perimeter of the glass. Most of them stay in place fine without adhesive and can be slid into the slot using WD40. There are some ribless ones which demand adhesive, gorilla snot works fine on them but make sure the slot is very clean. Gorilla snot is also a good choice if you want to use adhesive on a ribbed one, since it's actually fairly slippery before it sets up. In any case, none of it is rocket science, just a lot of elbow grease. You probably do need to remove the pane, although I've seen guys get tricky and work in the back with it tilted and then in the front with it slid back. I don't think it really saves any time or effort, so personally I just pop the panes.
I don't think your '90 will be any different from a '91, there's a good exploded drawing on BF-148 (pdf 1189) here: https://www.nicoclub.com/service-manual ... 2F1991.pdf
BCC93QT
1995 Infiniti Q45
So this car is destined for a paint job. No longer an oem option. Had a hard hit on shipping from Oregon. Totalled. As the doors and fender were pushed in upon shipping. Oem paint is not an option. Body kit. Paint is the likely option. Ive spent a few hours on making sure the VH45DE is running top. Abs unit needs replacement. New brakes. Tires. Rims. Pump. Hoses. Injectors were done a few years back. Not looking to do those again. Body...
BCC93QT
1995 Infiniti Q45
So i have actually used gorilla stuff on the sunroof a few years back
Working thst stuff on the top of a sunroof is tricky...
BCC93QT
1995 Infiniti Q45
So... amayama actually has them? Erm...
VStar650CL
Technical Expert
BCC93QT wrote:
Sat Mar 07, 2026 11:56 pm
Yep. I think they must be some sort of NOS, because they had the original p/n 91246-60U00 but not the superseding part K1246-60U00. Slightly unusual.
BCC93QT
1995 Infiniti Q45
Nope. Discontinued
VStar650CL
Technical Expert
Another lying website....
(and here I thought it was just Amazon)
.... :mad:
BCC93QT
1995 Infiniti Q45
Well lying. Idk
BCC93QT
1995 Infiniti Q45
Amayama has been actually a great source over the years
BCC93QT
1995 Infiniti Q45
My Q wouldn't be here without them. I actually got a bunch of struts from them before they stopped shipping them. Window covers. Window clips. Bunch of random stuff you wouldn't even imagine. You know those little black circles that rust out on your windows? They got em. If you got a 94-96. They got those fog lamp covers. They got the sunroof switches. The brake pedal green things. Fuel pump o rings. You have no clue
VStar650CL
Technical Expert
Then I think the best you can do is take some measurements and see if you can find some rubber U-channel which will do the job. McMaster has a good selection with exact dimensions. These are the rubber ones, but they also have foam and reinforced types:
https://www.mcmaster.com/products/edge- ... -trim-2~~/
BCC93QT
1995 Infiniti Q45
Im stumped. I have a few solid friends and mechs that are all in on this thing. Been holding on to this old girl for a long time.... I let both parts cars go last fall... Massachusetts....
BCC93QT
1995 Infiniti Q45
91246-60U00. Nope
BCC93QT
1995 Infiniti Q45
s***. Its not about lying my man.
BCC93QT
1995 Infiniti Q45
91246-60U00 done
BCC93QT
1995 Infiniti Q45
I understand. Its frustrating. Its not lying
BCC93QT
1995 Infiniti Q45
Nissan 80940-60U00 door trim. They actually tried
Ryantzer
If your sunroof is leaking you should clean out the sunroof drains. The seal around the sunroof isn't designed to be weathertight, which is why the sunroof drains exist.
VStar650CL
Technical Expert
Ryantzer wrote:
Mon Apr 06, 2026 3:47 pm
It sounds like @BCC93QT has a pretty big hole in the seal, and that will make rain splash out of the moving gutter and into the car with any heavy rain or a car wash. Even with a seal that's healthy 360 degrees, on most cars it only takes about 1/16" gap between the roof and the rear of the pane to allow splash to get past the gutter and invade the car. It's because the moving gutters are generally very shallow compared to the fixed gutters on sides and front, so it only takes a fast drip to get them splashing. Had one in the shop exactly like that last Friday, a gen3 Rogue that just got a new sunroof frame but the fixed panoramic pane was misadjusted slightly too far back. A tiny gap on the driver's side between the fixed and moving panes was letting through enough splash that the lady got suds in her hair at the carwash.
BCC93QT
1995 Infiniti Q45
Small hole rear. Not large hole but significant needs addressing. Car wash. Water comes in on passenger side windshield area. I guess thats common in this car
BCC93QT
1995 Infiniti Q45
Where the Gasket connects in the rear of the sunroof. Its starting to separate. About an inch now. I leave it in the garage. When I took ot threw the car wash today it definitely found the leak
BCC93QT
1995 Infiniti Q45
VStar650CL
Technical Expert
BCC93QT wrote:
Sun Apr 12, 2026 3:46 pm
That's exactly where splash can happen, because the moving gutter spans the whole rear edge. The same separation at the front edge would make hellacious wind noise but only let water in at high speed, because the fixed front gutter is part of the frame and is quite deep. On a side a gap like that might let in no water at all.
BCC93QT
1995 Infiniti Q45
So what have you found for a solution? Im about to get this car painted with a body kit... and I need info
BCC93QT
1995 Infiniti Q45
So theres 2 issues with water/sunroof issues.. When taking it through the tunel/new car wash. It leaks on the right passenger side. Coming from the windshield. This is common for this car. . The shroud on the sunroof is failing... thats the most important part. As this car is from Oregon the body is great. But not so much the accouterments.
VStar650CL
Technical Expert
BCC93QT wrote:
Sun Apr 12, 2026 6:19 pm
For the long term I think your only good answer is to have something custom made or settle for something that isn't factory. For the interim you can fill the gap. I'd imagine cutting some blow foam to the approximate shape and then coating it with black Plasti-Dip would probably hold up for awhile.
BCC93QT
1995 Infiniti Q45
I have a solution.... dont take it out the garage...ill figure it out
