nightheron »
https://forums.nicoclub.com/nightheron-u40239.html
Wed Sep 09, 2009 9:21 am
Thanks for the comments. I recently checked the compression and it was inbetween 170 and 175 lbs on all four cylinders, about the same as when I bought the car. I disconnected the negative battery cable for a while to reset the modem and it improved things a bit. I checked out the factory manual and there are about twenty things that can cause a rough idle, oh well.I don't know if it will pass smog, here in Eureka you only have to smog a car when you sell it.I thought that single cam motors are just getting broke in at 250,000 miles. Seriously I was thinking about pulling the motor and rebuilding the trans, replacing the motor mounts and timing chain, and getting the car painted, if I can get it done reasonably. Is this stupid? Would it be better to just get another car?
Modified by nightheron at 2:16 PM 9/9/2009
