Repo Man »
https://forums.nicoclub.com/repo-man-u194.html
Thu Aug 24, 2006 10:17 am
Well, first of all, welcome to NICO! How did you find us?
Secondly, you will not be able to interchange engines or headers with a 240SX because it is rear wheel drive and your Stanza is FWD. Also, 9-1 compression is not high compression. It sounds to me like you want around a 10.5-1 ratio to gain the greater power and volumetric efficiency, correct? If it were me, and I wanted to run NA (naturally aspirated) I would build the KA that is in it or I would drop in a FWD SR20DET.
Whatever you do, DO NOT buy a KA from a 240. You will not be able to use it. If you decide you must have a KA24DE, get one from an Altima. I have not performed such a swap and cannot tell you the details involved, but if I were going to that much trouble, I would be going turbo.
I'm also going to move this to the Stanza forum. Peace.
repo
