sticky_steve »
https://forums.nicoclub.com/sticky-steve-u52684.html
Thu May 22, 2008 3:47 pm
I was wondering if anyone has seen this, I have a 90 sohc and it runs just fine, but i was playing with the distributor. Advancing it about half a degree and it seems to run a bit better. But then the exhaust was making a different noise, and the engine rocks kinda hard when i stop. So i put the timing back where it was but the problem is still there.SSSSOOOOOwhat do you guys think, is the timing still off a little or what?and also i took off the cap and found out that at 15 BTDC the rotor is in the #1 position, but the wire thats on that contact point is #4. So I re-arranged the cables according to what everyone says, and no startup.
4 3
2 1
This is what my distributor looks like and runs fine
1 2
3 4This is what im told should work, but no workie.
Any help is appreciated
