RMiller »
https://forums.nicoclub.com/rmiller-u12169.html
Tue Dec 28, 2004 5:15 pm
If you're using an SR downpipe then you will either have to cut and reweld the flange on the dp or o2 pipe or use an SR o2 pipe. Or you can use a CA downpipe. Buy: -spark plugs. I use NGK BCPR7ES-11. I recommend BCPR6ES-11 for mild tune.-possibly timing belt. Go for oem, it has marks that make it easy to install. You can risk not replacing it but if it breaks it could do major damage. I replaced mine even though it looked perfect.-boost gauge-compression tester, or borrow one so you have an idea of the condition of your motor-tool for connecting wires, be it a soldering gun, wire crimpers and hardware, whatever. -lots of electrical tape-if you use a front mount, you need to relocate the battery or get a really small one. You can buy a relocation kit or an odyssey battery or similar.-new vacuum hose-new fuel hose in the engine bay-gear oil, DI water, motor oil, antifreeze
Many things most people don't think about before the big day, and I left out lots of stuff I bought in addition to the stuff above, like new gaskets, water pump, etc. etc. etc.
