nametakennow »
https://forums.nicoclub.com/nametakennow-u713.html
Sun Apr 30, 2006 4:44 pm
Do you smell gas as it runs? If an injector is stuck open, you'd be getting too rich so as to stall over time, and then you'd have to wait for the fuel to work its way out a bit before being able to crank it over again.
I wouldn't think that the fuel pump would consistently die after a few minutes, a dead pump is usually dead all the time. Same goes for a vac leak, you'd have trouble cranking and idling all the time if it was a vac leak.
If you rev it after those 4-5 minutes, right before it stalls, does it stay alive longer?
Welcome to NICO! Which motor is this, by the way? 1.6 or 2.0?
