D-oom wrote:ive been having a problem with acceleration lately. it studders around 2-3.5k rmps usually. if i hold the gas down all the way, i can harldly tell. if i accelerate slowly, it studders moderatly bad. i changed the fuel pump and didnt releave fuel pressure. but when i took the hose off, there was 0 fuel pressure.
You may have a plugged up fuel filter.
Here's a quick check on fuel delivery:An easy way to test the fuel pump and filter is to disconnect the fuel hose from the top of the fuel filter and insert a long length of spare hose into the top of the fuel filter with the other end draped over the fender going into a catch can placed on the ground. Now turn the ignition key to the run position but DO NOT START THE ENGINE. You should see fuel going into the can at a good rate for several seconds.
If it's OK, then you'll have to tee-in a temporary fuel pressure gauge at the filter outlet for measurement during operation.
The readings at idle should be as follows:- with vacuum hose connected to the fuel pressure regulator: 33 psi- with vacuum hose disconnected from the fuel pressure regulator: 43 psi
