1990 S13 KA24E Electrical issue
burntricer
Car: 90 S13 SR20DET Redtop
hey all, i have no tail lights, like their there but not working.
i have checked all the fusesi have changed all the bulbsi have signal lights that workbrake lights DO NOT worki know i have power back there cuz my wiper works
also i have no gauge lighting, the gauges themselves work, just not the lighting.
any ideas? or things to look for
burntricer
i have now checked the TCM/deck install/gauge cluster pinouts
TCM is fineeither pin #20 or 11 (red with blue) has power
deck install is done right with proper connectors
does someone have a cover for the fuses? that specifies which are which, all my fuses are good but i would like to know which is which
burntricer
update
i have traced the wiring back to the tails and found that there is a short to ground on all the connectors. i have the TCU and the headlight switch disconnected and still nothing works...
skylinekin
Car: 1990 Nissan 240SX Hatchback
I had similar problems, replacing the TCU with a good one fixed it.
KASilvia90
Car: 1990 Nissan 240SX KA24E M/T
You check all the fuses behind the fuse panel located to the left of the clutch pedal (driver-side kick panel). I had the problem happen to me, i removed my a/t shifting unit and poorly taped the old wires, grounded to the 5-speed shift lever and lost all interior lights, rear lights and im thinking side markers and something up front, maybe the running ambers but signals worked. It labeled "instrument panel fuse" or something like that... Did you check every dual-function bulb associated in that circuit that isnt working now? sometimes a filamant will break and cross something and it can mess with the circuit.
Madmax3
Car: 1990 nissan 240 sx
Check the brake switch on the brake pedal, Cost $6-7 at Advanced and fixed my problem. Even if it looks good if you have never replaced it do yourself a favor and replace it.
