1990 s13 aftermarket radio
big monkey racing
Car: 1990 240sx
i just got a new deck for my s13 and dont know how to tell if i have active speakers or not? also the end of my antenna wire is missing how do i go about replacing it? also does anyone have a breakdown of the wires cause the previous owners did a hack job and the factory connecter is missing? thanks in advance.
DamonDread
Car: 1987 Toyota Supra Turbo
Take it an audio shop and have them hook it up for ya. Might cost a few greenbacks but saves the headache of messing around in unfamiliar territory.
SoCal-S13
Car: 1984 Z31 50th Anniversary Edition VG30ET
where do you live. if youre close to so cal bring it by, ill take a look
big monkey racing
Car: 1990 240sx
its not the headache im worried im just looking for the wire color breakdown and what to do about the antenna wire.
Frye
Car: 1992 Nissan 240SX-RB20DET
just google 90 240sx wiring diagram, thats what I did. and 240's dont have a factory stereo ground, so u'll have to run your own ground wire from the new stereo to something metal on the car. I used the bolt under the ash tray.
eljoker
Car: 08 Impala
91 240sx base
96 del sol s
90 Chevy 454ss clone pickup
Well if you inist on doing it your self, this might help.
Speakers are going to be colored a solid color and solid color with a stripe combo
Like for exaple,
Green is positive
Green with black stripe is negative.
Now I dont know if the solid green is really the positive but you get the idea.
To see which set is which speaker, take a AA battery and connect one end to the top, and one to the bottom and you will hear a pop. That will pop will tell you which speaker it is.
Speaker colors should be
Green
Brown
Grey
White\
Hope that help.
cbt240sx
Car: 1990 Nissan 240sx
jbotch79
Car: '90 240sx RB25DET series 2 swap
'97 Audi K04'd 1.8T - DD
For the antenna wire, strip the covering off the wire. You'll see a clear covering on the inside. Strip this covering too and you'll see another set of wires. Go to an audio shop and ask them for the antenna connector. Strip this connector the same way you did the antenna wire inside the car. Wrap the inside set of wires together and tape them. Then wrap the outside wires together ans tape them also. Be careful not to mix up the sets of wires or touch some from the outside to the inside and vice versa when connecting them. It's hard to explain but easy when you're looking at it. If you have any questions don't be afraid to ask.
92_24Thb
hope this helps somewhat. if you need any other wiring diagrams let me know
for the active speakers or not, just look on the door panel. i dont know if this is true for all years but mine say it on the speaker grills
big monkey racing
Car: 1990 240sx
does anyone have the brackets for the radio or know a cheap site to get them/
SoCal-S13
i think i got one layin around. isnt the din attatched to a bracket, and that bracket also holds the radio? if so i have a din pocket with the bracket still
big monkey racing
Car: 1990 240sx
i believe there are just two brackets that hold the radio and the pocket below it. could i get a pic of what it looks like with the brackets installed and if you have those what would it take to get them?
SoCal-S13
big monkey racing wrote:i believe there are just two brackets that hold the radio and the pocket below it. could i get a pic of what it looks like with the brackets installed and if you have those what would it take to get them?
uhh ya ill have to take a pic in the a.m. and where do you live
big monkey racing
Car: 1990 240sx
i live in las vegas nv
