3Q Jay »
https://forums.nicoclub.com/3q-jay-u16163.html
Wed Sep 13, 2006 7:08 pm
hammer, maybe we're confused by your post. by 'front tie rods' are you referring to the tension rods? (between the tranverse arms and the 'radiator' subframe?)
i can tell you that the active tension rod carries a bigger bushing than the standard. i can tell you that there are different lengths of G50 tension rods both active and non-active to fine tune caster. i claim ignorance on the z32 tension rods, although i know some guys here use the adjustable Z32 tension rods on their G50's, but they then have a bearing in place of the bushing.
