It sounds like your injectors aren't firing. I got an ECU from a member on the forum that when I put it in it would crank over without firing. Of course after I put the original back it it was fine.
First thing to check is if the CEL light comes on when you turn the key to the on position. The next thing is to check the codes, with mine all I got was a solid red light. If you can check the codes than more than likely its not the ECU. The problem is that these early ecu's have a very small trace on the board for main power supply. This failed on mine as well as a capacitor. It looks like it could have been from use combined with a possible surge.
This is a 94' ecu, the 90 ecu has the same diode and capacitor just in different positions. The failure point is the trace between pin 45 and that diode. If you have a soldering iron you could solder a wire between the pin and the diode.
Its worth a look, its the only thing I can think of.
