Q451990owner »
https://forums.nicoclub.com/q451990owner-u223771.html
Sat Oct 05, 2013 9:49 am
The car has been sitting for 12 years, the tank has corroded, fuel pump corroded, I replaced both, 2 fuel injectors were bad #1 and #8 , I replaced those since they were accessible.
The car was driving great after there , but a slight vibration at 1500-2000 rpm.
I cleaned the mass airflow sensor and the intake as described in this forum.
I bought redline, that thing is strong. Within one day, the car started and when cold now it shuts down, and the car feels like its missing . Check engine light is not on, however, I noticed that it turned on for a brief few seconds now and then off. (the light)
I found out the guy who helped me did not change the original filter.... So I changed it. And brown stained gas came out... Full of powder like rust...
I changed filter 2 times now. But the car will turn off when in low RPM sometimes, mostly when cold, and is vibrating at 2000 rpm.
Are my injectors clogged due to the redline breaking loose the gunk and rust?
Why is the car shutting down now? Sometimes in the middle of driving ...
