Q451990 »
https://forums.nicoclub.com/q451990-u142.html
Sun May 27, 2007 7:15 am
How low is it? My first guess would be a dirty intake system, dirty throttle body, dirty IAC/AAC valve, etc. As a temporary cover-up, you might try opening the idle adjustment screw on the AAC valve. Do you have your FSM (factory service manual) that came with your Q?
Another possibility is a dirty Mass Air Flow sensor or a weak or corroded connection to it. Typically this will show up as a surging issue, but you might want to check that too.
Welcome to NICO!
Heath
