mattd1979 wrote:I read a post by Q45tech that stated that if I didn't use NissanMatic-D to use the Lubeguard Black because regular dextron III doesn't have the friction modifiers that NissanMatic-D has, otherwise use the lubeguard red.
I believe this to be the definintive post by TexasOil about Red vs. Black.
Lubeguard red & black
Red is synthetic sperm oil (can't kill whales anymore) and is used to smooth out the final engagement shock (lock-up.) It is a friction modified that lowers the coefficient of static friction relative to the dynamic friction. Dynamic is when the clutch faces are slipping past each other--static is when they are stationary.
Black lubeguard increases static friction and dynamic friction coefficients, raising the locked-up torque handling capacity of the clutch unit (results in 'firmer' feeling shifts)
The Q45 TCU/ECU backs off on torque during the shift to give smooth shifts. For a given transmission condition/temp/oil condition, one can 'tune' the fluid characteristics somewhat. Factory settings are a compromise between smoothness, durability, and performance.
Ideally you would get a continuous flow of driveshaft torque under all throttle and speed conditions, with no noticeable jerk or sag. Hard to achieve in this world.
You want to be careful with harsh shifts--they stress the metal parts and clutch faces (and driveline parts) more than intended. This is not to say they will fail (right away), but incremental wear/damage is unavoidable with hard shifts.
Regarding Lubeguard. (No comment on Nissan D fluid since I am ignorant of the specific characteristics) I AM knowledgeable on DEXRON (all previous and present versions) and the 'type F' fluids.
Q45's through version III for certain were designed for the friction characteristics of DEXRON. This fluid had friction modifiers that shallow the slope of the torque vs slip curve as the clutches approach 'lock-up'. AND these fluids are suitable for those cars that ALLOW continuous slip of the 'lock-up' torque convertor to smooth things out.
Some transmissons are designed for different fluids, ones that have either no drop in torque transfer as slip goes to zero, or even fluids that have HIGHER torque transmission ability as slip drops to zero. This characteristic is called HIGH STATIC FRICTION. Dexron fluids have HIGH DYNAMIC FRICTION.
If youput a 'high static' fluid in a transmission designed for 'high dynamic' fluid, you will significantly increase clutch lock-up shock--even to the point of shearing the metal driving lugs on the clutch plates. You may even feel a 'firmer shift', but that is easily confused and misnamed. You can also get a 'firmer [faster] shift with higher viscosity fluid or increased oil pressure in the transmission operating circuit. 'Firmer shift' and 'clutch lock-up shock' are different processes and not necessarily coincident. You can have 'soft shifts' caused by worn clutches, leaking clutch pack seals, low oil pressure, and STILL have 'lock-up shock.' You can have fast, firm shifts and still have smooth , no jerk clutch lock-up.
I recomend AGAINST adding Lubegard BLACK to Q45 transmissions in an attempt to get 'firmer shifts'. All you are doing is increasing the momentary torque loading( lock-up shock) on the metal parts in the transmission and can brak some real expensive parts. This transmission IS NOT designed for harsh shifts and WILL break.
IF your Q45 transmission has slow, lazy shifts at moderate and more throttle openings, slips on shifting (engine speeds up), then either your throttle position switch is misadjusted, the transmission is worn and leaking internally, the oil filter is plugged, the fluid burned (worn-out), the clutch linings coated with varnish (from infrequent oil changes) or the valve body is malfunctioning for some reason.
Change the fluid. Add one pint of Berrymans Transmission cleaner and seal conditioner--run it easy for a week, re-drain and refill with DEXRON III --not synthetic--most DEXRON III fluids already have as much as 50% 'synthetic' base oil in them to meet the very low temperature viscosity requirements. What you are trying to do is clean off the clutches, clean out the valve body, and renew the friction modifier additive package. IF the shifts are not velvety smooth on lock-up, add one pint of LUBEGUARD RED. Do not confuse 'smooth lock-up' with 'firm shifts'. DO NOT ADD LUBEGUARD BLACK trying to get 'firm shifts'. To get 'firmer shifts' you will need to increase the transmission 'line pressure'. There are after-market spring/parts kits to do this. Use at your own risk. You DO NOT want to create harsh clutch lock-up under any condition--the metal parts will not survive.
