1990 Q45 Frustration.....
silkysmoothyjud
Car: 1994 Q45
yes
silkysmoothyjud
Car: 1994 Q45
now, after bringing back the original prob...SINCE THE FREAKIN REPAIR SHOP PULLED MY #7 COIL PACK....THOSE, THOSE BASTARDS.....Those valves are loud...but gone, misfife when warm. Back to square one.....
Infinitiguy19
Car: 1993 Infiniti Q45 188580 Miles
1994 Infiniti Q45a 240000 Miles
Prime the HLA's: remove the Fuel pump fuse and crank for 15 seconds-Thanks Maxnix.
I am positive its the injectors making that ticking noise though unless you can provide audio evidence.
silkysmoothyjud
Car: 1994 Q45
Oh no, that was some engine rebuild noise...........update tomorrow
silkysmoothyjud
Car: 1994 Q45
HLA's? That injector is totally dead now.....I will find it tomorrow....
silver2k2
Car: 1994 Q45 Ivory Quartz/Tan
HLA = Hydraulic Lash Adjuster they type of valve lifter the VH45 uses
silkysmoothyjud
Car: 1994 Q45
silky smooth upon startup, 4 mile commute...starts out sputtering, then total misfire hard now, total injector failure kangroo hop. I should be able to find it easy now. We hope. Thank goodness I have a short commute, or my Q would be done.....
qship96
Car: 1996 Infiniti Q45
I see a friend of Bill Wilson in the making.
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
Why not consider rehabilitating the whole intake and fuel system?
Seems like you are just urinating upwind for now.
Read Heaths's thread on after market injector trial.
silkysmoothyjud
Car: 1994 Q45
And I agree, but I like to do 140 down highway 370 in my decade old car. I dont want to put any more than I have to in it.
Just as I feared, 5-8 are on the way out, failing one right after the other. Screw the multimeter test. I just used a pliers with a long handle and started pulling injector wires while it ran. When I found the injector, I pulled the coil pack plug too. You can test all of your injectors that way, cept for 6 I believe, the drivers side 3rd one back, I just pulled the coil pack to test it. Well here goes nothing, if it fixes it...you wont see me in this thread anymore....
silkysmoothyjud
Car: 1994 Q45
It fouled the #5 spark plug badly, totally misfiring. It was dripping wet with gas. Spark plug changed, oil changed and the problem is now solved. C-ya guys around....
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
silkysmoothyjud wrote:And I agree, but I like to do 140 down highway 370 in my decade old car. I dont want to put any more than I have to in it.
And how much life do you have left and what is it worth to you?
silkysmoothyjud
Car: 1994 Q45
A ton and very much!! Thank you for your concern, but 370 is a brand new highway out here with no traffic, a straight shot for about 75 miles; a real midwest autobaun. Just ask Jesda, highway 364 is another one. My brakes, pads and rotors are all OEM and less than a year old. My tires are not even a year old. It is perfectly safe to achieve a speed of 120, no problem. Niqole is perfectly smooth at that speed. I reached 140 in the Q a couple of times with my NICO ECU (buried the needle in my 04 neon at 120+, my cars love BG MOA) and I think 120 is as fast as anyone should need to go; Im just bragging. Most of my friends have reached ridiculous speeds in their cars/motorcycles on those highways. I take it there is no such place where you live, my condolences. It does sound crazy if you do not know the situation. My girl used to freak out, but she is used to it now.Plus, I have already did the plenum job, KS, new FP and I am about done with the injectors already. Niqole is at her prime and couldn't be faster. I have not had a car pull up next to me that I have not totally owned on the highway. I have not squared off with a vette yet...
Modified by silkysmoothyjud at 12:34 AM 2/8/2009
96Qowner
Car: 1996 Q45
silkysmoothyjud wrote: I have not had a car pull up next to me that I have not totally owned on the highway. I have not squared off with a vette yet...
Doncha just LOVE that about the good ol' Q45 luxobarge? No competition within miles.
... but you're gonna have some trouble with that vette.
