perulades wrote:i picked up the bulbs from autozon. the sockets look fine (not damaged/dirty). they are not getting electricity (no test light). i replaced the in-cabin fuses. are there under hood fuses that could also be causing problems? wiring also looks fine.
Check for power at the fuse (both sides) Bad bulbs and bad fuses account for alot of wiring problems especially on a car that has not been wrecked or is rusty. Even new bulbs and fuses are suspect.
Wiring is tricky I use to own a 66 Lincoln Continental that had a fuse block that looked like it had been stored in saltwater it was so rusty. I thought it would be a good idea to replace all the fuses and clean all the contacts-guess what? I created all kinds of electrical complications.
BTW if you think the Q is a complicated car you should see a 60's Lincoln, the vacuum hose diagram for the trunk release will make you queasy.
