saps5789 wrote:Thanks for the reply,How do i find out which injector is leaking.I do smell gas when this happens.I never tried putting pedal to floor before i turn ignition.when i disconnect fpcu why does the car still start.I still here the fuel pump running also.It only happens after car sits form 15 min to about 2 hours.always starts when cold.
With the FPCU disconnected, the pump won't run - can't be what you're hearing.
Also, the fuel rail remains pressurized when you turn off the car - it then continues to dump fuel past the leaky O-ring until the pressure is gone. After a couple hours, the fuel drains away into your oil, and you can start the car normally.
Check the condition of your oil. I bet it's full of gasoline. That'll be confirmation that it's a bad O-ring. If you can hook a Consult up to it, you may be able to determine which cylinder it is.
