For the record (to enhance this thread):
http://nicoclub.com/zerothread?id=47476
1990 Q45 Brake Pad R&R (BRAKE PADS WORN)nicoclub.com/zerothread?id=47476
Here is an excerpt from a related brake thread (so others benefit):
Q: Why can't I see the photos in this thread?A: Dunno. The photos are in the thread as of November 2004.
Some people find they have to go to the "user cp" user control panel button at the top of the NICO web page and then click on the "reset forum cookies" button and then hit the button to go back to their profile and then find the article again and view it with the photos. Sometime they have to go through that process twice before the photos show up. I suspect it's something in the user preferences and cookies setup. If you really need the photos and you can't get them, you can post a request to anyone to mail you the 12-page PDF of this helpful brake thread which you can keep by your side to do your next Q45 brake job.
Q: If the previous owner replaced the brakes, why is "brakes worn" lit?A: Brakes wear differentially; maybe only one axle set was replaced.
Q: Day 1 I hear sound of brakes wearing out; day 2 "brakes worn" lights?A: These two events may not likely be related (except coincidentally).
The warning light remains for hundreds of miles before the friction material is actually worn off sufficient for metal-on-metal contact.
I've personally driven hundreds (I forget how many, maybe 500 as Dennis said) after the warning light lit and I still had plenty (relatively speaking) of friction material left. The pads do wear unevenly though, so, it's possible one side is touching the disk while the other side holds the sensor. Also, the sensors are only on one pad out of four for each axle, so, you could hear one side hit on day 1 and then wear out the other side (with the sensor) on day 2. Since my sensor was plastic about 10mm in diameter, I doubt you'd hear it contacting the disk.
Q: Is this something I can order parts for and fix in my garage?A: Absolutely. The brake thread shows all soft & hard tools needed.
Q: I need factory pads in order to have the sensor for replacement?A: Nope. Aftermarket pads come with splice'able sensors.
Use factory pads & parts (from Joe) for different reasons (please see thread).
http://www.everythingnissan.com (
www.everythingnissan.com).
Q: Are Q45 brakes any more difficult than a muscle car or Sentra?A: Yup. Easy. Proof you can do it is that even I can do it.
While a Q45 brake job is relatively easy, there are a few tricks (such as imobilizing the front rotors and spnning the rear rotors to check runout) and FSM diagram booboos (like mis-splaced rear shims); so again, see the brake thread for the complete detail. That's why we wrote it.
Q: Should I replace the hardware?A: Do as qship96 says; get the hardware/grease kit from Joe.
In my situation, as the brake-thread photos show, my hardware kit was mangled beyond use. Using new hardware makes the job actually easier as the metal springs won't be warped hindering the new-pad insertion & motion.
Q: I usually just check over the rotors to insure that they are still smooth?A:Me too. I use my long fingernails and a dime as "precision" sensors.
In my humble opinion, far too many rotors are turned (see automobile articles in the thread backing up that supposition). Nothing wrong with turning rotors, mind you, except that most that are turned don't need to be turned. I think a groove can be 60 thousands before it needs to be put on a lathe (according to the referenced articles). That's thicker than a dime (if I remember correctly). Runout is a different story and should be checked with a dial gauge as shown in the articles.
Q: Won't the message clear itself once I change the pads?A: Yes. It will clear itself when you replace the sensor.The OEM sensor is much nicer than the Raybestos aftermarket sensor in that it's a complete wire that just plugs properly into the harness connector. The Raybestos aftermarket sensor splices into the wires and therefore may be error prone over time. Either way (I've done both), the message instantly clears itself up (unless you did the wrong axle, which happened to me as described in the brake thread).
Q: I can still use wood blocks and a c-clamp to push the piston back right?A: Why bother? Use a caliper spreader.When you remove the worn pads, the pistons will be all the way out. Push them back with a caliper spreader (I got mine at a local auto store for a few bucks). The caliper spreader (which remains in place while you do the brake job) keeps everything clean while you disturb all that brake dust & also prevents the kids from accidentally popping the pistons out by pumping the brakes when you go inside to bake some cookies or something.
Q: After we measure runout outside 0.0028 how do we correct it? A: Dennis explained it. We'd use thin shims behind the rotor.
However, I do understand your runout testing concerns. Here's my advice (for what it's worth). As Dennis mentioned (if I remember correctly), he checks runout and that takes him a long time. It took the longest time for me too. Here's a little secret. Most people, I think, do NOT check runout. So, you can do a pretty good job w/o that one test. Up to you, of course. It is better to check runout. But, I wonder if the local guys at Brakes-R-Us actually check runout? Does anyone have experience with this? Do the local brake shops take the time to check runout? Or do they just turn or replace rotors and consider the runout fine by default?
Q: Should I match the front/rear pads as Dennis suggests?A: Absolutely!
Notice Dennis' post above which says to match the pads. According to tests quoted in the brake thread, differences between stopping power were huge when there was a mismatch. Given that Joe sells pads at about the same price as aftermarket (in my case, anyway); and given Joe sells them cheaper that you can get the same pads for at the local dealership; and given Joe's OEM pads come with the correct sensor harness connector so there's no splicing needed; and given that you need Joe's hardware kit (if you can get it) anyway; and given that Joe's pads are to OEM specs (albeit perhaps not the original Q45 OEM specs), and given you still have hundreds of miles before a sensor trip turns into scraping metal (at least in my experience) ... blah, blah, bloah, I don't see any good rationale for NOT using Joe's OEM pads & hardware.
Q: How do I adjust the rear parking drum brakes?A: I never got that far so others will have to pitch in here.
The procedure for checking & adjusting the parking brake is on page BR-27 of the 1990 Q45 Factory Shop Manual (FSM), diagram SBR003B. A quick scan of that chapter reveals a shoe spreader (like all drum brakes) adjuster at the base of the drum and a front & rear parking-brake cable. There appear to be two length adjusters on each end of the rear cable (I didn't see any adjuster on the front cable, but, I may have missed it as the diagram is puny).
"]Q: If I don't get the OEM pads, is the pad wear sensor just unplugged?A: Dunno. Someone mentioned you might need to short the wires first.
DISCLAIMER: My only claim to any of the answers above is that I've read the FSM & done a brake job following NICO help every step of the way. I am NOT trained or qualified otherwise to answer any question above so take everything I suggest with a grain of salt.
