slshearer »
https://forums.nicoclub.com/slshearer-u32601.html
Mon Oct 20, 2008 3:34 am
Hello
I recently had all the calipers, brake lines and master cylinder replaced on my car, the brake pedal seem soft even after bleeding the system a couple of times, On the weekend the brake light came on and the fluid was slightly lower on the master cylinder, I topped up the fluid and the light went off, after driving through the mountains.
I stopped after driving and when I was backing up the brake pedal went to the floor, there was brake fluid leaking on the right side of the engine from the antibrake system (ABS) assembly.
I had the car towed to the repair shop and they advised a black seal had blown, do you think this was caused from excessive pressure to the ABS assembly. Do I have to buy a complete assembly or are there any seals available for the ABS Cylinder?
Thanks
