1990 Q45 and 1994 Q45 Fuel Injectors
hell-rell
Car: 94 Infiniti Q45 Base.
98 Ford Mustang GT.
will the fuel injectors from a 90 q45 fit and work properly in a 94 Q45? just wanna make sure.
BCC93QT
Car: 1990 Infiniti Q45
1995 Infiniti Q45
Need the 1990 fuel rails for them to fit. I wouldn't use the 1990-93 pintle tip over the 1994-96 rotary. The rotary injectors seem more reliable with ethanol
Q451990
BCC93QT wrote:Need the 1990 fuel rails for them to fit. I wouldn't use the 1990-93 pintle tip over the 1994-96 rotary. The rotary injectors seem more reliable with ethanol
^^^ that ^^^
You'd also need a new electrical subharness, and the rails wouldn't interface with the runners correctly either. What you're suggesting is a backwards step for sure...
hell-rell
98 Ford Mustang GT.
Ok thank you.
